Help Oil Cooler leak
Oahu, Hawaii
I have a 3fE motor and I have a wicked oil leak coming from in / around my oil cooler. What is the best way to fix it? Is there an aftermarket setup that would cool my engine better without having to deal with coolant lines and the rest of that mess down there?
Thanks,
Andy
Most likely its the hose or the o-rings. It's easy to take off. Just pull it and you'll figure what the problem is.
being as your in HI, could be rusted, might need a replacement, but start by taking it off and see what the problem is.
check the oil pressure sending unit for leaks as well...could just be that.
