I have washed it off... it came back.. sigh. I'll grab a btter pic of the cap/hoseWash it off with clean water and keep an eye on it to see if it happens again. Is the hose affixed to the elbow with the barbed nipple on the tank cap? Coolant should go out that way if there is overflow.
I’ll check cap and hose for blocks.
It looks like there's a groove where a seal or o-ring might be able to sit in the old reservoir cap. Might be worth checking the new one to see if there's a seal there.I just ordered a new OEM radiator cap and coolant reservoir cap. Stay tuned/
Hey @banditti, did issue go away for good after you installed the new reservoir cap?Old on the left, new on the right. You can see it is missing that rubber washer.
Mine is a 2011
Part No.: 16405-50080
CAP SUB-ASSY, RESERV
@Snafu13F, that's interesting. did you end up buying a new reservoir cap? If so, did it resolve the issue?Hmm, mine has been doing this since I had the radiator changed last fall. Do you have the part number for the reservoir cap handy? I’m gonna go check this.
Awesome. thanks for confirming.Yes sir
The rubber gasket under the cap is probably missing.Awesome. thanks for confirming.
any thoughts is to why it was spilling over with old cap?
you think just due to sloshing around while driving?
