Help me identify this part! Where do these wires go to?
In all seriousness, the wires from that connector go to the ECU and the ignitor, maybe the coil if I remember correctly, one or more being broken will result in no RPM signal to the ECU,, and / or no spark / signal from the ignitor.
The 4 wires from the distributor run directly to the ECU. The igniter/coil are on a separate set of wires.
The lock on that connector is nefarious and conceited. It decides to break if you look at it cross.
I used a zip tie diagonally around the plug to maintain the required pressure. Actually have done that on multiple cruisers rather than purchase another plug that will do the same thing. wiring is the devil.
