Gang:
I could use some help trying to narrow down a problem that just started (in last day or so). I think I know what the problem is, but I'm in a bit of a state of denial and I may have more than one thing (unrelated?) that may be confusing the problem.
Here is what I know / have done:
- Truck is a basically stock 1997 LX450 (excet for a fog light
) - no lift, stock size tires, OEM suspension (original AFAIK). It has ~126,000KM/78,000 miles. Synth fluids
- I believe (pre this list
) that the bearings were likely repacked on both sides about 2.5 years ago when I had some dealer work done to replace a part that broke in the front end (don't have the job sheet - looked like a large brass tube ==I shape)
- Replaced front brake pads with OEM about 3 months ago (rear were fine at the time)
- I lubed the drive shaft about two weeks ago - not too much
- While under there, I noticed what I didn't want to see - some 'battleship grey', liquidy oil on 'the balls'. This was after a day trip off offroading, including a number of water crossings (diff breather are extended)
- Here is where it starts to get a bit confusing/unrelated. I was talking to my wife today and she told me the brake warning light was on. I asked her to check the fluid level and she confirmed that it was slightly low - thought it was likely a sign the rear pads need to be replaced (light is now off)
- She also mentioned that the truck had a vibration at relatively low (city) speeds
- I just did a test drive and this is what I noticed: No vibration until about 20-25mph. It feels more the like the dash vibrating and a bit in the wheel. I don't hear any 'popping' as I make hard turns, but I do hear a sound of metal rubbing (not when turning - more when going straight). It seems to be on the DS and it isn't constant - nothing when I hit the brakes and nothing when I go over bumps. Maybe a bit more when I'm accelerating.
Based on reading some 'vibration posts' my sense is that (1) low brake fluid is likely rear brake and unrelated to anything and (2) I have a loose bearing and birf soup to deal with and this is causing the vibration.
I don't have a garage to work in, so I'm going to take it to my indi mechanic and see if I can get it on a lift to have a look. If it's the birf, I think I need to air freight from CDan and I'll go to my brother's house this weekend to do the job in his garage (need to buy a jack, stands, torque wrench,....but cheaper than the $2,000 bill I'm sure)
Thoughts?
Things I should look at / test to confirm the diagnosis?
Thanks for any help.
Cheers, Hugh
Thoughts?
Cheers, Hugh
