help finding a crankshaft pulley 3 v groove or a 2 groove outer pulley
fort mill sc
I have a situation with a replacement 2L - II engine that I am trying to fit into my 1986 lj70. I purchased a 2L-II to swap and found that the crankshaft harmonic balancer on the 86 2L has 3 v belt grooves with an outer crank shaft pulley. (basically 4 grooves) The old 86 lj70 2L balancer does not fit on the later model 2l- II diesel which has the 2 groove harmonic balancer with on outer pulley. (basically 3 total grooves). I need the 4th groove to go to the power searing pump.
So now I need either a 2 groove outer pulley to bolt on to the 2 groove harmonic balancer or I need a 3 groove harmonic balancer that fits a later model 2L-II diesel Hilux engine.
Is there an after market 2 groove outer pulley that can be retrofitted onto the 2 groove balancer?
I can't believe there are only 1 groove outer crank shaft pulley out there for a 2L engine.
thanks
rich
that looks like it. I am going to the junkyard tomorrow and if I fail I will take you up on this very kind offer.
