Hi all,
I've purchased an 80 series that has had a 2nd battery added with charge controller. Seems to work by getting the starter battery to 100% and then charging the house battery.
I have a camper trailer with the only charging mechanism being a 240 volt charger (New Zealand).
How might I setup a charging system to take excess charge from the cruiser (without depleting the starter battery) and add it to the trailer?
I have a redarc charger (like this) http://www.redarc.com.au/products/product/charge-equaliser_10a/
Should I tap from the house battery on the cruiser to an Andersen plug on the back of the truck... then make a lead to run to the trailer with the redarc equalizer attached?
I guess further down the track it would be nice to use the 12v Andersen from the truck to power a winch that is mounted via a hitch receiver to either the front or rear of the truck, that in my mind would make mounting the redarc in the trailer a more sensible idea.
Cheers!
Cheers!
