HELP - Catalytic converter gasket Part #s (1 Viewer)
PA
@hoser
Guys - my apologies and yes, I used the search.
I’m buying a new cat for the truck
I can’t figure out the part numbers for the fore and aft gaskets
Here’s the diagram. When I search 17451 for example - about 10 variations come up. Any help would be much appreciated
Should be this.... usual disclaimers apply! :)
(2) Post Cat <90917-06045>, superseded PN <90080-43028>
Add one more if you want to replace the gasket after the accordion/flex pipe between the cat and muffler
(2) Pre Cat <90917-06065>, superseded PN <90080-43036>
This is for both cats. Don't forget to buy all new fasteners
Rockauto has these gaskets for like $1.60 a piece (EASTERN 9024). I bought a ton as this is the same for 4runner (3rd gen)
Rockauto 9024
Part image
TOYOTA 90917-06045 (9091706045) Gasket, exhaust pipe | Plenty.Parts - All  you need to know about replacement parts
Might be okay... but might not be. If I was buying 100 donut gaskets, I'd certainly look further into it. But just 2? I'm still on the originals after 23 years while my muffler is starting to blow out its innards! lol. Surprisingly, no noticeable increase in noise yet.
Were you able to source the cat pipe? I inquired locally and was told on backorder...
Thanks for the reply...if I hear anything about availability will keep you in mind. Good luck.
