my 91 LC won't start, it'll turn over but not start. i've not getting any fire past the coil. i checked my FSM and it said to use a ohmmeter and check the primary coil resistance. it said if the coil tested at anything other than .41 to .5 to replace the coil. well it tested at .7. the secondary coil resistance tested ok. so i got another coil, i tested the new coils primary and it also tested at .7. WTF? the guy at NAPA said its probably the module (i forget what he called it) thing thats mounted under the coil. and that a new one is $250. what else could it be? any way to check the module thing? should i just bend over and take the $250? help guys
