- Thread starter
- #41
well i finally got it all straight..i was a combination of bad NEW NGK plugs and NEW wires..i replaced both the plugs and the wires again returned them and got new ones and it solved the problem..it is now running smooth and better power the it ever has as long as i have owned it..the only problem is since i cleaned the throttle body very well..it was grimmy..its now idleing at 1100 rpms and 850 to 900 in gear. Would you think it prob just needs an idle adjustment? Is there a idle adjustment on the throttle body?..i did not see one right off hand. But between the full tuneup and cleaning the MAF, throttle body, and changed fuel filter..i am so happy my LC is back on the road. While looking for the problem i also did a compression check and all cyl. came back even between 155 and 160 psi..not to bad for 195000 miles and the org. motor and head.
