Greeting from Woodstock, GA!! I just picked up my first LC a couple days ago, 2002 Black and Tan with 165k. First bout of rain and I’m running into some electrical issues. I have scoured the forum for like issues but alas nothing quite so similar. So, here goes- First, when leaving work last night the airbag light was on, I’d press the brake and it would turn off, that stopped after a while then the Red battery light was on, it dimmed out slowly after a while. Next up, the door locks would ‘sound’ like they’re locking/unlocking from just a rear door actuator and then quit. Coming to a stop and releasing the brake would engage the same actuator from that area. Happened about a dozen times. Result-no power locks at all once I stopped. Today, same lock issue, but driving tonight same actuator sound, but more rapidly, from the driver footwell, happened twice.
I have checked for water intrusion on both footwell fuse boxes and ECU’s, and pulled all fuses to confirm that they are in good shape. I’ll pull fuses under the hood tomorrow, but my assumption is it’s a ground fault somewhere (great).
With the wealth of knowledge on this forum I was hoping someone might have run into a similar issue.
BTW, less than 12 hours after owing the truck I had to have some Tundra wheels. Here she is.
