NeverFinis
ooh...I hope the rumor is true because I have approval to buy one!
I heard from a reliable source that the rumor of discontinued was so the stock could be cleared out as they have a newer version. Haven't heard anything about the differences.
Originally posted by johnfj
Thank you photoman now it makes sense the pulley is over the nose cone I'll give pboys a call and see what they can do they have ones for other trd packages. If the tables abover are correct a 2.6 should yield 9.5 inches though my truck is only making 5 on the stock pulley. This is all being done so to optimize a water/alcohol injection system. I'll listen to any advice on that.
I have already solved the fuel delivery side, though not a very eloquent solution.
Can anybody tell me if on a 94 if changing the base timing at the distributor will really full the computer or will it just full me on the advance curve shift?
JohnPhotoman,
Being from a different age I reallly didnt understand the computer thing. Hindsight being 20/20 the seventh injector or 8 does not really matter with a simple controller would have been the way to go, but I went mechanical. I bought a FMU the at was variable which was smart because as much as I calculated using websites tools there were too many variables to lock in on set ramp. I installed the fmu set it up with 60 psi at atmospheric pressure via experimentation. this defenitley took care of my flat spot as boost ramped up. then I tried to adjust it to what I calculated to be 90 psi at wot and 275 hp. It had two problems the first was I was getting eratic fuel pressure readings at highway speeds as load changed, and secondly I could hit 90 psi for a few seconds at wot and then it would drop to 70 psi and here comes the pinging.
Solution for both in hindsight are easy but they didnt come quickly. The first is the eractic nature of the fuel pressure came by the ecm swtching between low setting ie the resistor circuit and full voltage all controlled by a vsv and I assume an algorithm in the computer.
It's been a year since I did this test John, but I'm pretty sure this is a idle switch only resistor circuit. Any other problem with it means you should be staring at the fuel pump relay or TPS switch/adj.the fix is simple though for me not instantly intuituive and that was to let the computer do its thing since there is no feedback from the resistance circuit to tell it that happening and jumper the resistor out of the equation.
The only negative is that now rail pressure at idle is 40 psi versus 33 but I have linear smooth power all the way up.
The 2 nd problem was solved by installing a second fuel pump in series in the engine bay. the trick I learned was the pump cant run all the time or your rail pressure at idle is way out there at 50 to 60 psi. So I purchased an adjustable pressure switch and after trial and error have found if it triggers at 2 psi boost I can run up to WOT with noe of the pinging and power loss etc.
What led me to all of this madness was 2 sets of knock sensors and 2 sets of catlytic convertors and fortunatly not a new engines yes can we say melt the wire looms when the cat melts and clogs the exhaust.
