Hello. A few questions about the Supercharger from Kazuma.
Discussion in '80-Series Tech' started by Ma70.EnT, Aug 20, 2006.
  1. Ma70.EnT
    Ma70.EnT
    3
    Aug 20, 2006
    My dad's 96 Land Cruiser has a Kazuma Supercharger and we're wondering if there are any places that sell pulleys that will allow us to raise the boost pressure on the Supercharger. Also, what other parts will be needed to deal with the increase in boost? I'm guessing a better fuel pump, injectors, and an aftermarket ECU (or something along these lines?).
  2. airlaird
    airlaird
    1,346
    4
    Jan 7, 2005
    Dallas, Texas
    Good question...I often think about going to a smaller pulley..I believe you may run lean on a smaller pulley...hopefully others will chime in.
    airlaird
  3. Ma70.EnT
    Ma70.EnT
    3
    Aug 20, 2006
    Yeah, I'm hoping to get help sometime soon.
  4. elmariachi
    elmariachi
    1,977
    23
    Jan 4, 2005
    Shufflin' Through the Texas Sand
    I have the next size smaller pulley that came directly from TRD, but it will require that the offset be set by a machine shop. Offset is the amount of standoff away from the face of the blower and determines the alignment within the belt track. It would be set by having a machine shop measure the existing pulley you have and then mill some of the shaft of off this one; common stuff for blower setups. PM me if you are interested in it.
    Jim.
  5. cruiserdan
    cruiserdan SupportingVendor Emeritus Moderator
    22,205
    6,261
    Mar 27, 2003
    Land Cruiser Heritage Museum broom closet
    The stock pulley is 3.2 inches. I have a 3.0 inch that I run from time-to-time. Mine was offset corrected by a friend. Increased boost will reinfoce the requirement for premium fuel and 100% perfect cooling and fuel systems. Do not be surprised if you need to do something custom to provide additional fuel.
  6. DarioCarrera
    DarioCarrera
    73
    13
    Dec 14, 2005
    Venezuela
    Youll also need a new belt... given the smaller dimensions of the SC pulley...
  7. SUMOTOY
    SUMOTOY
    1,836
    6
    Jun 1, 2005
    Chicago
    Is more really better?
    I did a bit of research on this a while ago. The problem I have is with the numbers that Eaton puts out for the M90. I'll try to find all the calculations I put into my spreadsheets, but my conclusion of it all was that the M90 output at 6-7psi on a 4.5L DOHC motor was about maxed out in terms of compressor output vs engine CFM. You can spin it faster, but in reality the compressor efficiency will drop, and the max air ouput doesn't change. A big inline 6 of 4.5 liters with dual overhead cams can flow a lot of air.
    I suspect you could do more by optimizing the heat, the injectors, the fuel pump, the fuel pressure, the ignition timing of the truck, intercooler, and yield more benefits than adding the smaller pulley.
    Bottom Line: The TRD M90 is well matched to the engine size at 7psi. The biggest comment I get from other M90 owners is how quiet the 80 application is. I believe this is because what the charger puts out, the engine moves thru.
    All that said, if you want to run more, you really should do the fuel pump, injector sizing, fuel pressure regulator anyway. So start there, and add the pulley if you want.
    In my shop I work on turbos for a living. Boost is an addiction. My job is to make sure more has more benefit. In the case of the M90 on the 1FEFZ motor, I believe it's well matched to the stock pulley. A dyno would really determine if more boost gets you more output. The spreadsheets I've put all this through, says don't get your hopes up.
    Edit: Here's more notice the CFM output of 5psi vs 10psi, specifically split that difference, you have gained maybe 20CFM?
    http://www.automotive.eaton.com/product/engine_controls/superchargers/M90.asp
    Putting 7psi into my CFM spreadsheet with 85% volumetric efficiency I get ~500CFM airflow thru the engine at redline which is probably a bit over actual... What this all means, is that the M90 is *just* adequate for the needs of the 1FEFZ. If you take a gander around, for performance (as apposed to 'gain'), the Eaton M112 would probably be a better choice for this motor. The problem I have with the M112, is it's not known to be very efficient at lower boost levels, but flows a lot of air at higher pressures.
    HTH and my .02
    Scott Justusson
    QSHIPQ Performance Tuning
    Chicago
    94 FZJ80 Supercharged
  8. cruiserdan
    22,205
    6,261
    Mar 27, 2003
    Not an accurate statement for this application. I use the same belt for both pulleys.
  9. Photoman
    Photoman SILVER Star
    1,162
    Media:
    39
    Albums:
    2
    103
    Mar 28, 2003
    This is a chart that was originally published by the dealers that were selling the supercharger. I don’t know if the information came from TRD or where.
    _______________________________________________
    Land Cruiser Pulleys
    Code:
    Pulley Size  Max Boost Max Horsepower@4350 rpm*  Max Torque@3350 rpm*
         2         12.5              358                   434
         2.2       11.5              347                   422
         2.4       10.5              335                   410
         2.6        9.5              323                   399
         2.8        8.5              311                   387
         3          7.5              299                   375
         [COLOR=yellow]3.2        [/COLOR][COLOR=yellow]6.5[/COLOR]  [COLOR=yellow]            288                   [/COLOR][COLOR=yellow]363[/COLOR]
         3.4        5.5              275                   351
         3.6        4.5              264                   340
    *all figures represent at flywheel
    Yellow shading represents initial supercharger configuration
    Adding a pulley that increases the boost over the base, emissions-legal pulley will require additional modifications, possibly including ECU and fuel delivery systems. At this time, Kazuma does not supply these additional modified parts, but may be able to assist you in sourcing them through other aftermarket vendors.
    It is possible (barely) to install down to a 2.6” pulley with the stock installation. Smaller than that the crank drive pulley would have to be moved out along with the belt tensioner.
    A few pictures showing the different pulleys and pulley work being done. The black pulley is the stock 3.2 inch.
    Bill
    Edit: Added 100 HP from the spreadsheet figures I used to agree with figures from link in next post.
    Supercharger-pulleys-four-s.jpg SC pulley difference other side.jpg Supercharger-Pulley-Work.jpg
  10. Ma70.EnT
    Ma70.EnT
    3
    Aug 20, 2006
    I saw a chart similar to that in this link:
    http://www.wctoyotasport.com/Parts/00646-17620-501.htm
    Code:
    Pulley Size Max Boost Max Horsepower @4350 rpm* Max Torque @3350 rpm*
    2.00 12.5 358 434
    2.20 11.5 347 422
    2.40 10.5 335 410
    2.60 9.5 323 399
    2.80 8.5 311 387
    3.00 7.5 299 375
    3.20 6.5 288 363
    3.40 5.5 275 351
    3.60 4.5 264 340
  11. SUMOTOY
    SUMOTOY
    1,836
    6
    Jun 1, 2005
    Chicago
    More on Kazuma numbers
    Hi:banana: version:
    Ok, I corrected my spreadsheets for the dyno numbers above. If I use the above chart, the correction factor of 2.1CFM per HP allows me to input the above boost pressures, and get est flywheel hp within a couple hp published above.
    That translates to a 1.00 Volumetric Efficiency at 3350rpm (peak torque) and 85% Volumetric Efficiency at 4350rpm (peak HP) and 80% VE above that. Bottom line: the Kazuma Eaton M90 supercharger is out of airflow at 10.5psi. You can get peak hp at 4350 and 12.5psi, but it'll drop like a rock after that. And consistent 12.5psi runs over 4350rpm (whatever injectors you use) will overheat just about everything downstream of the SC outlet!
    Lo :banana: version
    I'd consider the 8.5psi as max, as that gives less than 10% CFM cushion, which has always been where I tag forced induction comfort zones. The 7.5psi pulley (3.0in) Dan uses just makes the 10% window, without regard to any offestting changes in compressor efficiency.
    Switch to the Eaton M112, and Christo would have a lot of competition to his turbo ...
    HTH and My .02
    Scott Justusson
    Chicago
    '94 FZJ80 Supercharged 3.2in pulley
  12. Photoman
    1,162
    Media:
    39
    Albums:
    2
    103
    Mar 28, 2003
    Weird. It seems that every HP number I posted is 100 less than the ones from that link. Mine were from a spreadsheet I got several years ago. The ones from the link seem more realistic as SUMOTOY pointed out, so I would disregard the ones I posted.
    Bill
    Edit: Changed my numbers to agree with those in the link posted. That sure was an easy way to get an extra 100 HP.
  13. SUMOTOY
    SUMOTOY
    1,836
    6
    Jun 1, 2005
    Chicago
    Bill:
    If it makes you feel better, my spreadsheets kicked your chart data out with red Andromeda strain flashes: Volumetric Efficiency out of range. Since your numbers in the right hand column were the same, and the left were only 100 different, I added 100 to that HP column and all was well again, VE between 80-100% (100 at peak torque, 85 at peak hp).
    I wonder what was left of the truck that was tested at 12.5psi. I suspect that part of the 'ECU' modification would have been a 4350 redline. :doh:
    SJ
  14. johnfj
    johnfj
    32
    1
    Jul 17, 2007
    Who sells the smaller pulleys and why do they need to be custom fitted if the factory pulleys are not
  15. Photoman
    1,162
    Media:
    39
    Albums:
    2
    103
    Mar 28, 2003
    You can try here to buy some pulleys. I never dealt with them so don’t know anything about availability or application. The reason for machining blank or generic pulleys is to get the drive belt to line up. Also, as the pulleys get smaller in diameter they will not fit over the nose piece on the supercharger so pulley material has to be removed. This will work to a point around 2.6” IIRC when there will not be enough material left to support the belt. If you wish to go to a smaller diameter than this it might be possible to flip the pulley which would allow it to clear the supercharger nose and would stick out approx. ½” farther. The crankshaft drive pulley and the belt tension pulley would then have to be spaced out the same to keep the belt in alignment. This would strain the supercharger bearings a bit more as it would be driving them from farther out. You might also want to put a parachute on the head. :eek: Another option of course is to fabricate a larger crankshaft drive pulley to overdrive the supercharger pulley. It is a bit more work to swap out the crank pulley as opposed to the supercharger pulley. LOL, while you are at it, you could make a little larger pulley to overdrive the alternator and AC compressor for more low RPM amps, more AC, and faster ruination.
    Bill
  16. cary
    cary
    3,118
    43
    May 7, 2003
    I suspect the truck was theoretical and therefore was only theoretically harmed.
  17. steveVA
    steveVA
    73
    Oct 4, 2004
    Richmond, va
    So it says on the Kazuma site that the supercharger kit is available, that's good news because I thought superchargers were not available anymore... Just the TRD SC discontinued I guess??
  18. johnfj
    johnfj
    32
    1
    Jul 17, 2007
    Thank you photoman now it makes sense the pulley is over the nose cone I'll give pboys a call and see what they can do they have ones for other trd packages. If the tables abover are correct a 2.6 should yield 9.5 inches though my truck is only making 5 on the stock pulley. This is all being done so to optimize a water/alcohol injection system. I'll listen to any advice on that.
    I have already solved the fuel delivery side, though not a very eloquent solution.
    Can anybody tell me if on a 94 if changing the base timing at the distributor will really full the computer or will it just full me on the advance curve shift?
  19. johnfj
    johnfj
    32
    1
    Jul 17, 2007
    Sorry about the typos
  20. Romer
    Romer fatherofdaughterofromer Moderator
    10,794
    2,003
    Sep 14, 2003
    Centennial, Colorado
    I heard from a reliable source that the rumor of discontinued was so the stock could be cleared out as they have a newer version. Haven't heard anything about the differences.
