2001 LX470 160k miles.
We are on a trip from LA to SF and back and stuck half way home right now. Here's the skinny:
Started as a mild random jerk to the drivers side front wheel on the way up (not me, the steering wheel). I stopped about 3 hours in because it kept getting worse. The next day, it was fine so we continued.
No noise associated with it. No grinding. No clicking. No thuds, whacks, or demonic wailing. Turning/braking does not improve it or make it worse.
I jacked up the truck to wiggle the front wheel. No top to bottom slop. No side to side slop. I think that rules out ball joints and rod ends.
Rotating the wheel revealed some driveline slop and a mild clunk. I'm guessing it is normal, but not sure.
It really only presents when coasting. Acceleration seems to at least suppress it. Very light throttle can give a light wobble. But taking my foot totally off the gas makes it jump to the drivers side and shake heavily through the steering wheel.
It almost feels like the lug nuts are really loose. It seems to be much better at the start of trips. It drove with no symptoms for almost two hours. Then it started getting bad enough we stopped for the night. Now it is going to be Sunday. I'm not sure we are going to be able to find a mechanic tomorrow and we are about 3 hours from home.
I'm guessing a CV is giving away, but I'd expect a click on turns with that. A friend is guessing a the wheel bearing, but there has been no noise and the rim wasn't hot to the touch after hours of driving.
Any ideas?
Thanks in advance!
Any ideas?
Thanks in advance!
