I have a problem with the heater valve on my 94. The valve itself will move freely with the cable taken off. The cable barely moves with plyers and not at all with movement of the temp slider. Is there a small motor that is burned out that can be replaced?
My problem looks to be from a replaced hose on the heater valve that when replaced the person performing the fix used hose clamps. Well the clamp to the right side of the valve was blocking the valve movement. Really a stupid oversight on whoever did the fix. Im guessing that the motor that moves the cable is burned up and needing replaced.
My question is what is the actual name and/or model # for the replacement part? ALso I am going to dig into the dash to try to find it as well. If anyone has any help or pics please let me know. Thanks alot.
