Heater hose clamp part number needed (1 Viewer)
Azle, TX
I’m changing all of the cooling hoses, and I’m having an issue getting the right clamps for the heater hoses. Partsouq and the local dealer called out 9613652101 for the top hoses, but they are too small (they seem correct for the lower hoses). I would need to compress these just to get the on the hose, and there is no way they would clear the lip of the fitting.
I was planning on doing it today, but now next weekend. As (un)luck would have it, my starter is getting flaky, so I’ll knock them both out when the starter comes in.
That’s the right part number.
Were all 6 of your hoses the same diameter? My lower hoses are smaller diameter and that clamp is correct for them.
Yes, same diameter for all 6 heater hoses. The only ones that aren’t the same are the two that run down the firewall/footwell to the pipes under the cab that go to the rear heater. Those are smaller.
Mystery solved. At least for a 2000, the Toyota parts diagram lists the wrong part number for the clamps for the upper hoses. The correct clamp (silver) is the part number listed for the rear heater hoses under the truck. The part number listed is for the clamps for the two lower hoses (black, bottom of the Ts).
About to replace all of my hoses and clamps as well. Do you have a full parts list? I've also got a 2000 LC. Reading through part diagrams to try and make sure you get what you need for your build date is... fun.
My current clamp list -- which may be wrong based on the above comments but match the part diagram and the wits end link:
For lower radiator hose bottom (radiator side): 9046743002
For lower radiator hose upper (engine side): 9046742001 (has been replaced by 9046641008)
upper radiator hose radiator side: 9046742001 (has been replaced by 9046641008)
upper radiator hose engine side: 9046741006 (has been replaced by 9046641008)
So are you all saying all four need to be the silver/gray kind from the lower radiator hose bottom (9046743002)?
Likewise per the PartSouq part diagram I am seeing these clamps for the rest of the cooling system hoses:
2x 90467-13054 - clamp for water by-pass host (replaced 90467-13059)
6x 90467-20011 - clamp for water by-pass hose clips
8x 96136-42501 - clamp for water by-pass hose No 2
4x 96136-52101 - clamp for inlet and outlet A
Edit: Ahhh I think the Wits-End link was supposed to be this kit for the heater hoses instead of the radiator hoses that were linked above: 100 Series 2UZ Heater Hose Kit - https://absolute-wits-end.com/100-series-2uz-heater-hose-kit/
It calls for 12x 96136-52101, which disagrees with my list and from what I've taken from the parts diagrams.
Give me a day and I can put the whole list together. All of my comments above are in reference to the six hoses on the heater Ts. The clamps for the radiator hoses look correct.
There is a cooling hose on the fuel injection diagram, that I ended up paying through the nose for because I didn't catch it on the partsouq diagrams. Again, give me a day.
Thanks, here's my list but I've only gone through it twice and both times it was pretty late... may not be accurate. I'm going to check it again after I drain coolant this weekend to see if any of the aluminum the hoses connect to are pitted then order my parts.
In short, thanks and no problem on giving it a day!
