After thinking about doing this for a few months I finally swapped out my stock seats and dropped in a pair of Saab heated leather seats. the brackets from the stock cruiser seats can be removed and installed on the Saab seat quite easily... you need but drill one hole. The seats are a bit wider but still work okay... the e-brake touches the driver's seat when engaged. Two small adapters needed to to be to bolt in the rear inboard mounts and two holes needed to be drilled to mount the front inboard mounts. Looks fine... and you wouldn't even see it if the carpets were installed... mine aren't as a bed liner application is in the near future. Not exactly diesel specific but I did install them in a diesel... which, btw, is now running on B100 biodiesel. Purchased in a 100g pre-pay for $3.10/g.
oops... meant to post this elsewhere... sorry.
