Began working on a customers Landcruiser last week. He had an intermittent 300 code, 305 code, and a slight shuttering and lack of power when the vehicle was hot. Most notably when first accelerating after a stop, and then again around 2000 RPM.
With no previous service records, I went ahead and replaced plugs, wires, distributor cap, rotor, and coil. I also replaced the air doctor because it was cracking and brittle.
The shuttering affect continued. And if driven enough miles, the 305 code might appear. It did a total of two times. That is with over 300 miles in test drives trying to duplicate the issue.
The issue only occurred when the vehicle temperature was 186 or higher, the air intake was over 120.
I hadn’t paid attention to the fact that his heat shields were gone. I believe that this caused the temperature of the mass airflow sensor to increase significantly above normal, and caused the issue.
After installing new heat shields, I have not been able to duplicate the issue. To test my hypothesis, I took off the heat shield and brought the temperatures back to where it was experienced originally. Sure enough, it through a 305 code, and the shuttering persisted.
I reinstalled the heat shields and have driven several miles without any further issues.
The customer has had their vehicle back for almost 2 weeks now, no further issues.
I’m not 100% convinced that I have isolated the issue but it appears that I have. Has anyone else come across something similar?
