Heat pump heat recovery system
Trollhole
THC
Supporting Vendor
Moderator
Mauldin, SC
Website
forum.ih8mud.com
Had been thinking about this for a while. Looks like someone is already doing it.
Heat Recovery System
Basically in the summer your heat pump removes heat in the air in your house and vents it outside. What if you could use that heat to preheat your water heater?
Heat Recovery Water Heating
What is Heat Recovery Water Heating
Heat recovery water heating is the heating of domestic hot water with the waste heat from the air conditioning system. This heat is rejected from the air conditioner's condenser to the atmosphere. By recovering this wasted heat and utilizing it to heat water, it is possible to substantially reduce water-heating costs.
How much Hot Water can be Recovered?
An air conditioning system with a water-cooled condenser, while producing a ton of refrigeration or 12,000 BTU per hour of cooling capacity rejects approximately 15,000 BTU per hour of heat to the atmosphere. An air conditioning system with an air-cooled condenser rejects about 16,00040-17,000 BTU per hour of heat for each ton of capacity. 3,00040-5,000 BTU per hour per ton is relatively easy to recover with a very nominal investment in equipment. This is virtually free heat.
A residence with a three-ton air conditioner could expect from 15-to-25 gallons of hot water raised from 70 to-140 F every hour the air conditioner is running. With a five ton air conditioner a, possible 25-to-40 gallons could be recovered. This hot water would be available during the summer months when the air conditioner is running fairly consistently. As the outdoor temperatures decrease the air conditioner will run less thereby making less hot wafer available. With heat pump, hot water from the heat recovery system is available during the winter as well as the summer months.
Even greater savings can be realized in some type of commercial establishments where the hot water requirements are heavy and there is a high internal heat gain from lights and people in the public area causing the air conditioner to run even during the winter months. Some restaurants, motels and Laundromats have been able to obtain 100% of their hot water during the cooling season from the heat recovery system. The following figures show the gallons of hot wafer that are attainable with a 70 F temperature rise.
