Headlight issue.
San Antonio, TX
I have a problem thats killing me. The headlights low beams will not work. The bulbs are fine as are the fuses. The high beams work fine too. Only thing I havent checked is the stalk switch. Has anyone else encountered this problem?
Can you hear the relay click? If so then it's not the stalk. If not then it could be the relay. Pull it out and check to see if the stalk is grounding the appropriate leg with the stalk is switched to ON. If so, it's the relay, if not its the stalk.
