- Joined
- Dec 27, 2006
- Threads
- 10
- Messages
- 104
got 85 runner 22re,leaks coolant,thought it was hose from water pump to pipe it wasnt.So get out handy pressure tester,pump up to 30 psi and it appears to be leaking out of head gasket near front and rear of engine on driver side(unless it is just running down between head and block from some hidden place).First question,has anyone seen this type of leak before?and is there any other common spot on rear and front of head that is hard to see that is prone to leaking.I know that toyota is prone to head gasket trouble but I have never seen one leak externally.Darn aluminum cylinder heads!!!!
