HDJ81 Fusible Links (1 Viewer)
found the much clearer image of 90982-08265
here :
Are the wire colors enough to identify what I'd need?
This is exactly what my setup looks like except the FL that bolts to the glow 1.25b is physically attached to the connnector FL (90982-08266). It is black in color. My problems started when my accessories started to lose power (radio, dome lights, clock, door sensor light on the cluster). Where should I go from here? This pretty frustrating of Toyota to use the same part number and sell completely different parts.
i have run across this ONLY 1 time before
It must have a unique to it stand alone part # ?
a fellow member in CANADA ? I don’t know if his truck was a JAPAN spec. Or not ?
you should have a BLUE stand alone fusible LINK wire correct ?
are you physically IN JAPAN right now ?
View attachment 3198352View attachment 3198353View attachment 3198354
I was stationed in Japan and recently brought my Land Cruiser back with me. Currently in South Dakota. The black wire here with the ring terminal appears to be what I need attached to the FL connector you have for sale as PN 90982-08266.
ok
that other member in CANADA i mentioned , i started to hand craft him this , but i did not have the FINAL TECH that you provide some what above ?
i do NOT know the needed ring terminal size ALL the links wires are proper MM
this IS without question NOT a 90982-08266
its a yet to be confirmed part # , maybe one of the ones on my screen shot above ?
i PM'd you too BTW
go see it please
i think i can help you TODAY on this , perhaps ......... 🤔
Looking for some help to determine the period Correct Color-Coded Tracer Stipes harness side wire for the grey fusible links connectors ?
i am gearing up to hand craft the harness side pigtail repair kits in the event of a melt down that can happen
thanks
Is this the set that goes to the black box with 1.25B Glow and 2.0L Main? Do you sell these? I have a 1991 HDJ81 from Japan that also runs the the 3 wire FL but I can use this and combine with the 90982-08266 that you make.
what might be better here , 🔮
- you POST PHOTO's here in this TECH Thread please , i can then evaluate what all you have going on set up wise , then we go from there
- this way you can be sure and so can i ...
thanks
matt
let me give you a better image here
also , if the 08267 is NOT correct , i keep on-hand ALL gauges fusible links wire and 99% of the needed connector plugs too , i kustom make fusable links as part of well ....
what i do for a living , here at the skunk works Laboratory
have you ever seen my ANYTHING JDM / Diesel TECH fusible links master thread i started a while back ?
i have documented all the variations i have come across and been asked to reproduce exactly same in kind , all i need is good pics of a verified original specimine photos
to work from , ...
and let me tell you what my friend , there seams to be NO dam limit to all the different one off one modle year only part #'s used here and there around the world !!
i venture to say there are well over 100+ unique and different vintage Toyota land cruiser links at the very least .........
and is NOT a over thought at all ....
Hey I know I'm super late to this thread, but was wondering if you had any fusible links for the 1993 hdj81 rhd.
He doesn't reply so good luck
Hello folks
hi mr.
J2P ... :)
it's been super busy here in the last several months , after summer on and off roads driving season ,
Now fall TLCA events , and the beauty of Autumn colors are upon us as well ,
- i made a significant and well .......... it so was that TOYOTA had 2 variations as much as i have been able to deduce after more then a pile of late night R+D hours into
what you have above ....
- i NEVER have been able to establish 2 different part # 's for the 2 clear variants , so the updated one wins the day , because everyone still needs all 4 links at the end of the day too ...
-so this is a win win , and i like win win for the folks i Skunk-Works these up for :)
- i incorporated ALL the related Later revised links into 1 single part , because more and more i was seeing EXACTLY what i painstakingly HandCraft below to precise period correct Fit Form Function , Format ...
Hello folks
hi mr.
J2P ... :)
So you've got it figured out what a '93 HDJ81 needs for fusible links, as shown above? I never did get around to getting you pics of mine, but I'm ready to buy if you've got the details from elsewhere!
Hello folks
hi mr.
J2P ... :)
Great work, I’m ordering 2.
- update all things fusible links :
The
90982-08266 HDJ80 HDJ81 Fusible Links have a safe and secure long term future being carefully handcrafted in-house at the Rising Sun Mechanical Skunk Works Laboratory & being offered via VintageTEqParts family run online parts store .
thanks for your support
make sure to click
ON the speaker ICON lower RH corner , turn up volume to max 🔊
enjoy
Does anyone know the status of @ToyotaMatt or VintageTeqParts? I placed an order for the HDJ80 fusible link about a week ago and got an automatic order email, but nothing since. I also DMed him with no reply. Thanks!
