Has anyone had a Hewitt bypass quit working? (2 Viewers)
Baton Rouge, LA and Gunnison, CO
Here's the story, my 2006 GX470 started throwing the codes and go into limp mode this past winter and a few times this summer. So I ordered the Firewater Marine bypass kit. When I installed it there was already a Hewitt bypass installed. I uninstalled the Hewitt bypass and installed the Firewater kit. I haven't put enough miles on it to know if it works or not and haven't had time yet to see if the block off plates are already installed.
Just wondering if I have a different problem or the Hewitt kit did go bad?
There are a few known incidents that Hewitt themselves know with first generation bypass. It can go bad. That is just from reading Paul Hewitt's comments on GXOR.
I am batting different issue with rutech bypass. Lately its been giving me P0113 for intake temperature sensor current high. Replace MAF sensor with OEM and it still comes back randomly on hot days.
I have a Hewitt kit on my 2007. It went into limp home mode 2X last winter, under cold conditions where I hopped straight on the freeway after starting the engine. However, I've also found that the ground wire for the Hewitt kit likes to come unplugged. So I crimped down the connector a bit more. Not sure if that was my issue or if the Hewitt kit is no longer working. I'll see how it does later this winter and then evaluate other options.
It could be your MAF connector myself. I've had the OEM one go bad - and then my splice job on the replacement to bad later one. A bad MAF plug will cause all sorts of codes and issues. Others have also had this problem. I've since spliced in a new one, including making the connector easily replaceable by adding a Deutsch connector to the OEM harness, then another Deutsch connector to the MAF pigtail.
Interesting Rednexus. My MAF plug was broken and taped together. That could be my problem.
Do you have the part #'s for the plug you used?
I used one from Amazon, but the pigtail was kind of short. Since your MAF wiring isn't pre-hacked/cut like mine, that might not be a big deal. You could cut off the OEM MAF plug, add a Deutsch connector in it's place, and then add a Deutsch connector on the end of the MAF pigtail. Or you can direct-splice, but the splices have to be really good to not have issues down the line like my rig did.
I'd post pictures of my new/improved splice job, but the forum is giving me a server error message. Here's the MAF connector.
EDIT: Server is working.
Here is the new pigtail I made:
And it installed. The Deutsch connector on the ECU side can be seen attached to my ARB twin mount.
i broke the MAF plug on my tacoma, and I got a pig tail but i didnt splice it in. i depinned the old connector and just used the new connector body and plug the old pins into new body and everything worked fine. didnt have to splice anything and worry about it not being working right
My connector was not broken and physically looked fine. It also snapped onto the MAF fine as well. I think the issue was the actual pins/wires inside of the connector. For both instances, the issue fixed itself as soon as I put on a new MAF connector. The MAF wires are only 24 or 26 ga wire so the they are rather fragile when they get old. Or, perhaps the connector pins aren't gripping the pins of the MAF very well. The MAF is pretty sensitive; if there is a poor connection or slightly higher resistance due to a wiring issue, the ECU will mis-read engine airflow and cause all sorts of strange problems.
I have a 2003, so no SAIS on mine.
However, Hawkeye Garage just posted a YouTube video and posted on GXOR about his new fix for this issue.
He had problems with bypass kits, so he and his buddy posted what they call a permanent fix that you can DIY
I had one of those that was previously sold by slyfox75 on eBay. He's NLA, perhaps he got a nasty letter from USEPA. It also threw the PO2445 code, which is why I tried the Hewitt. Not sure if I had a wiring issue with that kit or something else.
Can't help but wonder if this is a ECU issue caused by my tune. Maybe the ECU tune of my rig has the SAIS "bug" in it, as I don't ever recall having SAIS issues prior to loading a tune on the rig. Some more experimentation this fall might address it. I'm also not opposed to pulling the intake off and fixing the SAIS parts as opposed to bypassing the system.
I replaced the MAF connector plug, cleaned the contacts, then hooked up the new Firewater Marine module. Started up and my GX ran rough at higher rpms, and threw the same codes again. So I unhooked that one and hooked up the old Hewitt module. It ran great, no codes, drove it 150 miles yesterday from the mountains to town, towed a trailer with my Rzr back to the cabin. No codes. Hmmmm.
Hewitt is redeemed.
