Well I just purchased the Harbor Freight Jack that this thread was started about. It is called a 2 1/2 Ton, Heavy Duty, Long Frame Jack and after seeing it, I was really impressed. I checked several other stores and couldn't even find anything to compare it to I got it on sale for $119, and got the 2 year optional full replacement warranty for $20, which seemed like a good idea considering this is a China made jack. Tax and all came to $153.
Wow! This thing is big, heavy, and looks to be built pretty stout. It's got a 46" long T-Handle, and also a foot jacking pedal. This foot pedal is nice for getting it up quickly to the height you need, and I used it with my hand easily, then the T handle is easy to pump to lift the heavy 80 series Cruiser. The center knob in the T-handle lowers the jack, nice and smooth, slow or fast. I said it's big, and it's about 48" long, or 53" OAL if you include the foot pedal. It's pretty much all steel with rubber grips on the T handle, and plastic grip on the center knob. Wheels front and rear are steel and even the mounts for the wheels look very sturdy. About the only flimsy thing on it is the jacking mechanism cover, which is thin sheet metal, with indentions in four spots and it snaps into place. This is on the top rear between the handle and the vehicle, and shouldn't be a place that needs solid steel. I am concerned if the hydraulic jack itself will hold up, but I was suprised to see the paperwork came with a new set of seals and instructions for disassembly, and states more seals can be gotten from HF.
The jack looks huge, but when you roll it under a lifted 80, it looks to be in scale. The long length really works well as now I can jack it up easier from each axle without its handle hitting my bumpers like my old 3 ton regular length floor jack did.
The jack is rated to lift 31" tall, and I verified it in the store but that was with no weight on it. Using it to lift my Cruiser a foot off the ground to the pumpkin was easy enough. Then I slowly lowered it down to the jack stands and it was very controlable.
My old jack had leaked from the seals and now with these instructions, I think I can replace them to use my old jack again which will be nice to have it going for a backup.
For the money, I don't think you can go wrong with this jack, especially coming with seals and instructions on rebuilding it. That was a big plus that I didn't expect. Time will tell how well it will hold out. If it last long term, I sure would like to paint it as I hate the orange and white color, but then maybe your a Tennessee fan. I would like to repaint it, maybe put some aluminum diamond plate on the jack top cover, and put some ARB, Land Cruisers, or whatever stickers you have laying around on it. Then again, it works well as is.
