- Joined
- Sep 4, 2020
- Threads
- 112
- Messages
- 1,508
- Location
- Brunei Darussalam
- Website
- eurasiaoverland.com
Hi All
I'm rebuilding a circa 1988 H55F from a BJ60. Where I live, it's not as simple as buying a new H55F and swapping the input shaft, so I have to do a piecemeal overhaul. I was hoping to re-use the output shaft, the rear splines are perfect (and it's -60071 with the longer splines than the currently available -60072) but on the journal for 1st gear there is some minor pitting. I think the vehicle was sat for a long time and the previous owner seems not to have been keen on changing transmission oil. See the photo below.
I've cleaned the area with some 1500 grit wet-and-dry. The black marks are negative features (i.e. holes in the surface). In my mind the long needle rollers won't really feel these imperfections as they do not extend far across the journal. Also, the bearing is only moving when the gear is idling - it is never moving under any load (though as first gear it will be spinning almost continually during use, often at relatively high speeds assuming the box is in 5th).
I don't mind replacing with a new shaft, but I'm not keen to spend several hundred dollars on something which would be fine. What do you think?
For those that are interested, the transmission had badly worn gear teeth on the input shaft, rounded shift teeth on 3rd and 2nd gears, some corrosion on the inner race of first gear, rounded splines ends on the 1st - 2nd synchro ring assembly and worn splines on the 3rd - 4th shift hub (splines on the output shaft look and feel fine). All these items, as well as all bearings and synchro rings will be replaced. The counter shaft, 5th and counter 5th gears are fine, even though the box was not running an oiler cup (can't see the point of them anyway, but will add one when I rebuild).
Thanks
EO
Thanks
EO
