For Sale H55f parts
Denver, CO
I have a brand new (in box) LHD shifter for an H55f ($140) 33530-60100
and a brand new (in box) input shaft for a 13BT to H55f ($SOLD) 33311-60111
Part numbers added to the initial post. I have no way of looking up the part numbers at the moment to see direct application. As I recall, the input shaft was purchased to go with a 13BT, so it would be "late". There are a large number of splines on the input shaft (fine vs coarse), so you might need to match clutch disk accordingly if you are swapping. I can count the splines if that matters to you.
You gots PM!
Deal pending on shaft. Shifter still available.
It's been a few years since I ordered it, but I seem to recall it coming with a 1HZ I purchased. If it's the same as the other one I had, it's set up for a LHD wagon....no so much a stock 40 or 45. I had originally bought one to replace my RHD shifter in the 40, but decided it came to close to the steering wheel for my liking. In an ideal world, I think the 40 series shifter would be set at 0 degree rotation from centerline. If you had an aftermarket small diameter steering wheel, I think it would be fine.
Bummer. I'd be looking for one to go into the 45....
You don't have any pictures of it do you?
Dan
Input shaft is sold.
Shifter is still available.
