GX 460 2023 warranty coverage (1 Viewer)
Boston suburb
To make sure - Lexus warranty coverage:
- is transferrable to new owner
- basic is 48 months/50,000 miles - from day of original purchase
- powertrain is 72 months / 72,000 miles and covers engine/transmission/drive shafts/axles/hub bearings/differentials (all 3)
Correct?
Thank you!
This one says 2022, but 2023 is same
Warranty coverage is automatically transferred at no cost to subsequent vehicle owners.
Powertrain Warranty This warranty covers repairs needed to correct defects in materials or workmanship of any component listed here and supplied by Lexus, subject to the exceptions indicated under “What Is Not Covered” on pages 19–20.Coverage is for 72 months or 70,000miles, whichever occurs first. Engine Cylinder block and head and all internal parts, timing chain and cover, flywheel, oil pan, water pump, fuel pump, engine mounts, engine control computer, seals and gaskets. Transmission and Transaxle Case and all internal parts, torque converter, clutch cover, mounts, transmission control computer, seals and gaskets. Front-Wheel-Drive System Drive shaft, axle, hub, bearings, seals and gaskets. Rear-Wheel-Drive System Differential carrier assembly, driveshaft, axle carrier, axle case, axle bearing, axle shaft, seals and gaskets. Restraint Systems Warranty This warranty covers repairs needed to correct defects in materials or workmanship of any seat belt or airbag system supplied by Lexus, subject to the exceptions indicated under “What Is Not Covered” on pages 19–20.Coverage is for 72 months or 70,000miles, whichever occurs first. For vehicles sold and registered in Kansas, the warranty for seatbelts and related components is 10 years, regardless of mileage.
Youll also see some 8yr / 80K items
Yes, it should be. Just read the fine print.
Usually the only non-transferable warranties are for vehicles with life time, like some of the Chrysler 300's some years back that had a lifetime bumper to bumper warranty, but it was NOT transferable.
