[quote author=Rich link=board=2;threadid=14475;start=msg138097#msg138097 date=1081834633]
the fundamentals of electricity are getting thoroughly mangled in this thread. [/quote]
You're right again Rich.
Apparently you believe that voltage potential is some magical quantity that exists independent of other electrical phenomena. ??? ??? ???
Voltage potential is a function of current and resistance. End of story - don't bother trying to explain your way out that. When you place one lead of a voltmeter on the battery ground and one lead in the coolant you're getting a reading that is a function of the small amount of current flowing between the leads and the collective resistance in the path that the current flows. So is the voltmeter giving a reading of conductivity, resistivity, or amperage? No, it's giving a reading of volts but that reading is dependent on the resistance of the system. It's all related Rich!
I guess the simplest way to end this is to look at your own actions. You've measured the potential between the coolant the battery ground. Why would you do this? Obviously you're trying to assess the state of the coolant. What could the coolant possibly add to a voltage measurement? What would you conclude if you went back a week later and found a different reading? Does coolant spontaneously generate voltage? current?? Nope, the coolant serves as a resistor in the circuit and that resistance (conductance) presumably changes over time, and this all possibly ties in to how "good" your coolant still is.
Plain and simple and, yes, a fundamental of electricity and circuit analysis.
