replaced the front diff gear oil about 3K miles ago.
76K on rig, no indication that Birfs and seals were ever redone.
Oil took a definite black tinge to it. Presumably the result of some black grease from the knuckles. No indication of Birf soup coming out of the knuckles, so if the seal is weak, it seems to be only in one direction.
Had the breaters extended and opened around that time too so the diff is not likely sucking grease in from the knuckles by vaccuum.
Anyway, either there is a bit of grease coming in from the knuckles or the oil got dirtied from earlier grease remaining in the diff despite drain (unlikely).
Either way, there is some grease in the oil. Oil, at least near the top, seems very fluid still, not soupy.
Question: would a small amount of grease be detrimental and dangerous to leave in there? Heck, it has moly so could be a good thing?
More specifically: OK to leave as is for the 2K freeway run to Moab or is it imperative that I change it first?
