Feels better up in the rarified air doesn't it?......Looks great!
Time for 315's for sure.
Total install time was about 4 hours in my garage w/ some air tools. Not necessary, but made it "easier" and less tiring. First rodeo show in a suspension setting so it went well. No broken bolts, nuts etc .... nothing was stuck. Didn't even pre-soak anything with PB Blaster or the like.
i just got my lift on as well and had the 315 Duratracs installed. I also put on the OME J on the front and 863's in the rear. I like the set up a lot so far as well as the tires
I'd be curious if you run in to any front driveshaft vibrations or growling at higher speeds (45-50 and above). Mine is doing it so I'll likely have to go to a double cardan driveshaft.
