MaddBaggins said:Check your lugnuts and tire pressure first![]()
You made me think, I've never had a vehicle aligned. I've never had anything pull to the side enough or wear tires in strange ways to ever cause me to get one done. Sorry, no help
I am not yet ready to let Mr. Baggins off the hook for anything yet
MaddBaggins said:After all the grease we spilled together, this is what I get!
We did birfs together, I thought that meant something![]()
No need to mark the ground.1. Draw a straight line on the surface you are parked on that is parallel to the direction of travel, (ie the frame).
Correct, then measure between the marks.2. Draw a verticle marker line on the rear of the front tires.
Push the vehicle forward to a point where your marks are about the same distance off the ground on the front side of the tires as they were on the rear, about 2/3 tire rotation and then measure between the marks.3. Push the vehicle forward to a point where you can measure the deviation of your tire marker line and the reference line on the floor.
Yes larger tires will make a tiny deviation, if your into getting it that close, here is a page for you.I am thinking that the increase in tire size will effect this measurement, unless one uses a fixed diameter (ie the hub or wheel) to measure forward motion. I am too tired right now to calculate the error, but it should increase the deviation by some percent.
