Build Goat. A 1967 survivor FJ-45 LWB
Then I added the @65swb45 approved cup holder
Would create a cup holder out of an old Coca Cola crate. *
(I own two of them brought from the USA)
All you need is a saw and some rusted nails
http://c8.alamy.com/comp/BGB6KC/rusted-nails-BGB6KC.jpg
or glue & red paint. :)
Cheers Peter
* Wooden Coca Cola cup holder.
Design trademark by Doctor do Little.
Hey, maybe you can use the front drive now!
Early 1F vacuum question:
This truck runs great so I’m wondering what I’m missing here.
I think the PCV for this truck is here on the oil fill tube. It’s wide open and the carburetor base plate is plugged.
Hook it up? Is this PCV still available or should I put an in line valve here.
Brilliant advice. The OEM PCV is goner. This one is a replacement and it is doing nothing either
I guess I’ll just put a later PCV in line north of this one and see how it all runs.
I changed the oil and cleaned the oil bath filter element. That was interesting. I’ve never seen one before.
I got the housing mostly clean. Good enough for this old Goat.
Lastly I moved my OEM gas can from Patina to the Goat. It just needs to be back here
The 4 corners of the bed floor are seperate pieces of metal attached at the wheel wells with large phillips head screws. With that said it appears to be a patch under that spare tire.
Yes, separate pieces..
