Howdy Mud:
Got myself a 'interestingly maintained' L31-Block (Series 1) 350ci Vortec FJ60 last summer... and have been slowly working the bugs out.
...all kinds of fun things have happened:
Burned plug wires on Block-hugger headers, cooked a distributor, cooked cats running lean, replaced entire harness with a Howell EFI, newer spider injectors, etc.
New problem: OBDII code PO441.
GM's VCM labels this as "Evaporative Emissions Control System: Incorrect Purge Flow"
Which, by my estimation, means the flow from the charcoal canister into the intake manifold is either too much, or too little.
I've made a diagram of how my FJ60's OEM emissions system is hooked to the GM engine bay:
(The highlighted YELLOW in the above image is where I believe the potential problem to be.)
Here's what I've found as potential causes/repairs:
-Bad Gas Cap
-Bad vacuum switch
-Broken or damaged EVAP line
-Broken or damaged Charcoal Canister
-Open in VCM purge command circuit
-Open or short in Voltage feed circuit to Purge Solenoid
-Faulty purge solenoid Restriction in EVAP solenoid, line or canister
-Corrosion or resistance in purge connector
-Bad VCM
As such, I'm going to start with the stuff on the green list.
If anyone has experience with these old Vortec's, or knows likely culprits in the "Octopus Wah" of vent hoses from the separator through the body... please let me know! I've heard, also, that placement of Emissions components (e.g. the Charcoal canister) could definitely affect the performance of the system, as could the lean-running conditions that cooked my cats last fall. Anyone got 411 on that?
Thank you.
I'll post updates as I go along...
-Bad Gas Cap
-Bad vacuum switch
-Bad VCM
Thank you.
