Forget the toyota FIPG. Get yourself some Permatex " The Right Stuff " and do it yourself.
It's on my trans pan and oil pan. No leaks - easy to use - just don't over do it. We're talking five minutes and you are in business.
The busted stud on the oil pan - unless it's in a critical position forget about it and let the gasket material take care of it.
It ain't rocket science. Whatever you wear though plan on tossing it if you get a lot of ATF on you. Stuff reaks and won't come out.
There's no ATF filter to replace. Spray the stock metal one out with BPC and put it back.
If you really want to get fancy search for ATF fluid filter change from coolant line. I've done it several times - I don't think it's worth the trouble if you follow up with another drain and refill in a reasonable amount of time.
