Hey All,
I need to flush the gas out of my Fj40. Tank is a third to half full (5-10 gallons), but fuel is about 20 years old. Do you think it is sufficient to shake the cruiser then drain the tank, refill with a gallon of fresh gas and repeat a few times; or do you think I need to pull it entirely and flush? Since there was a good deal of gas in the tank, I was thinking that maybe it didn't settle out too much, as would have been the case if it evaporated dry -- similar to what my carb looked like (varathane muck). Note that I do plan to replace all fuel lines, filter and the fuel pump.
If I do need to pull and flush it, what is the best method. The cruiser has very little rust so I doubt there is rust in the tank.
Thanks.
Brian
Thanks.
Brian
