If the option was available who would spend the extra and get a diesel?
Cheers,
Nick
Cheers,
Nick
Fortunately for you, current EPA regs require turbocharging on diesel engines.nickw said:I should also: a Turbo is a must.
If Toyota does not put it on, we sure will.
But I doubt Toyota would sell a new truck without a turbo. Especially the FJC.
Cheers,
Nick
Sort of. EGR is to reduce cylinder pressure and therefore combustion temp. A similar effect is achieved by stretching cam timing and using an undersize turbocharger. The turbo will blow a lot of air through the engine, which reduces the percentage of trash in the exhaust gas, and lowers combustion temp. Lowering the CR is also a new emissions requirement.Alacrity said:Jim:
Hmm...Is that how they are doing EGR?
Just that.Read in the WSJ that EPA had relented (again?) on 150k/10yr FUL - heard anything on that?
FJ40Jim said:But it all reduces combustion (fuel) efficiency compared to the
optimum cam & turbo combination. What we are seeing is spark
engines w/ increased compression & direct injection, and
compression engines w/ reduced compression. The fuel efficiency
of diesels is going downhill
Just that.
