G2 Tundra Crewmax cab - water incursion???
LINUS
Waiting for the Great Pumpkin
PNW - WA
So realized I damp carpet back behind RR seat in the ‘12 crewcab/crewmax in sig.
It has that sliding glass RR window that drops vertical & is the entire window.
I also have the glass moonroof.
I did pressure wash/ wash mitt - the RR glass area some ~2wks prior.
When I noticed it, I found the FR 2 drain holes for the sunroof & ran an Amazon brush down them.
I don’t have the FSM for a Tundra, has anyone here cleaned what I would expect the RR 2 sunroof drains???
Or is the RR window glass known to leak a bit if you hit it with a pressure washer???
Anybody here chased this one??
Have you checked the 3rd brake light?
No.
Never occurred to me that was a problem area.
-Is that a common issue?
I’m still on OE bulbs / have owned since ‘17, doubt original owner had any reason to remove in 1st 5years owning it.
I hit it fairly decent same time as RR slider glass as I have a headache rack I pulled out when it went for a spray-in bedliner & got rid of a Tupperware liner that rattled @ highway speeds.
Pressure washer was dialed down to 1/3 power, it’s the Dewalt / Honda magilla one.
Is the 3rd brake/bed light a weak link in the leaking issue?
