FZJ80 front brake calipers: Are left/right the same, or no?
ozarkmud
PNW
Hi everyone,
I ended up with two Toyota remanufactured front left brake calipers. It says it on the box and the bleeder valve would be on the top for the left and on the bottom for the right. The rear calipers are clearly mirrored.
Is this normal? Can I put it back together? At first glance, it seems like it can bolt up.
Part number 47750-60060-84 for both.
Did the dealer make a mistake?
Thanks!
They are side specific. IIRC the other side should start with 47730-
Ask the dealer to recheck the part numbers.
Hi everyone,
Thanks!
All four calipers are different from each other. 4 different part numbers per truck.
Thank you! I contacted the dealer and will be swapping out a front left for a front right. Should be good to go in a couple days. Now to also take care of a leaking axle rear seal...
