FZJ80 1996 Rear ABS Wiring Routing
The Netherlands
Hi all,
I’ve got an intermittent ABS code for the left rear sensor. Installed new suspensions a couple of weeks ago, so I suspect a stretched or broken wire near the rear axle. Will be sorting that out.
But when checking the wiring I noticed that my ABS wiring between the axle and frame is tie wrapped to the UCA. I would like to return this to factory when I’ve repaired the wiring.
Tried searching but I cannot find a clear picture of how it is supposed to be mounted.
Does anybody have a clear picture of the mounting between the axle and frame?
Thanks!
