Fuse help (1 Viewer)
Charleston, sC
Which fuse is for the round plug in the wireless charging area? I'm not understanding the acronyms on this cover and don't have the wiring diagram.
I suspect you may find that fuse in the smaller interior fuse box underneath the steering wheel to the left.
yep
Passenger Compartment Fuse Box №1 (left)
Fuse #4 10amp
cigarette lighter
(Four-wheel drive system, ashtray, cigarette lighter, brake controller, cool box, cruise control, center differential lock, multi-display assembly, seat heater, air conditioning system, glove box light, emergency flashers, audio system, headlight cleaner switch, inverter, driving position memory system, outside rear view mirror switches, overhead module, roll sensing of curtain shield airbags off switch, shift lever switch, steering switches, VSC OFF switch, console switc)
yep
Fuse #4 10amp
cigarette lighter
Found it, was actually fuse labeled p/outlet. And, you need to be an acrobat to get to that box, and fat fingers make it even rougher.
I hear you. I just added 2 fuse taps to that fuse block. Not as bad as getting to the top bolt on the back shocks, but it is up there with PITA items.
yep
Fuse #4 10amp
cigarette lighter
So, if the fuse I replaced "p/outlet" fixed the round plug on the wireless charging area, then that makes me wonder what the #1 fuse "cigar lighter" is??? I would have thought that was it, but it wasn't blown.
Possibly the one for the second row (back of the center console)?
Simple, pull it and see what doesn't work. :hillbilly:
Are you looking for this fuse specifically or are you just looking for an ignition hot fuse inside the cab? If so the Wiper 30 A fuse is what I chose. It is the last fuse (towards the firewall) in the third row (towards the outside of the truck). From my testing the "cig" fuse or what I thought p/oulet was, was constant hot. I could have mistaken that but wiper is a good bet for ignition hot.
@Moby, I used the wiper fuse for ignition hot as well.
