fuse for rear window?
Fuse for the window
Attached to the wire both sides
Glass motor at end
.........you need more words than my haiku to get a real answer.
In third world countries solvent abuse (glue sniffing) is a common problem. Here, not so much, I don't think.
Guess we're just lucky to have these two...
So do you sniff glue-
Or find it a real world issue?
No answer so far.....
You might want to give the year of your rig, symptoms, what the core issue is - etc.
Have you even been under the dash looking aat your fuseblock / used a ohmmeter yet?
Otherwise silly / stupid haikus will be the best tech you get......
I have an '04 sequoia, 2x2, sr5 with 137k.
From my question, one might conclude that my back window does not work. But solvent abuse kills brain cells... lots of them.
I didn't mean to rattle your cage. Here's a couple links to make your "life" easier!
Last, but not least: www.youtube.com/watch?v=ZfYFx6MOTYU
You brought up glue Sniffing, kid.
With your attitude I’m now not going to tell you anything helpful save it’s a 30a fuse.
Good luck / have fun.
Does your defrost and wiper work?
Yeah - since been reading that there is some kind of brake on the window itself, designed to prevent it from falling during repairs?
I hit the switch with the motor off the other day and I heard clicking sounds so fuses are ok.
Thanks for replying :)
I'll be doing the timing belt etc. the next few days. Get the alternator done. Belt, tensioner and idler. Bought a new three-row radiator - no pink milkshake for me!
Then a new differential. Hope I can buy a limited slip?
After all that I'll be back to the small stuff again :)
Like, for example, the track off button... lol
