Fully Automatic Factory Service Manual (FSM) Downloading (10 Viewers)
1997 Land Cruiser RM: In the Brake section there's one that for some unknown reason won't download. It's "Load sensing and Proportioning ...".
Nate,
There is an ampersand (&) in the filename. I'm guessing that is causing a problem with the WGet command.
-B-
Yup... sorry guys tracking and fixing this bug to make sure other stuff isn't affected... will be done shortly!
Nate..
I'm having the same trouble fjfar80 had right above this post. After everything runs thru in the black command box, nothing gets downloaded..... I still have the same 1KB files.
I have no "Sygate" to turn off..... I don't know what that is!!!
Let me know...Thanks
Boz my first guess would be your cookies.txt file.
Make absolutely sure you follow each step in the instructions step by step. Work s-l-o-w-l-y and don't skip anything because it is all essential to getting it working. If you still have trouble shoot me a PM and we'll work on it from there.
-----Nate
-----Nate
Nate,
Thanks for being there!!! You're right, you gotta do this exactly as instructed!! My fault was NOT highlighting the asterisks where it says "paste your cookies here"... so I copied it wrong!!
Thanks again for answering all the questions!!!
:bounce:
There ya go! Glad you got it working :cheers:
My instructions are a bit jumbled. Maybe when I'm feeling more organized I'll try to clean em up.
------Nate
Nate,
-B-
Is there anyway someone could fix this and download just this section for me? My 24-hr subscription expired. I.e., the section on "Brakes - Load Sensing and Proportioning...". Would be much appreciated.
Excellent work.
Would you mind making packages for the 1994-1999 Celica and the 1990-1991 Camry? If you have time the 1990-1993 Celica packages would come in handy as well.
Thanks.
Whoa... That was not supposed to be public. Apparently I need to redo my .htaccess file for that directory. It has been removed.
Here is the new Celica stuff..
1990:
Toyota Celica ATM Unit Repair
Toyota Celica Collision Repair Manual
Toyota Celica New Car Features
Toyota Celica Repair Manual
Toyota Celica Technical Training
Toyota Celica Wire Harness Repair
Toyota Celica Wiring Diagrams
1991:
1992:
1993:
1994:
1995:
1996:
Toyota Celica Owner's Manual
1997:
1998:
1999:
Nice. Camry packages all downloaded perfectly as well.
I didn't see it mentioned in the instructions but can I have more than one package and wget session going at once or will that cause problems with my cookie?
You could have more than one going at once I suppose, but I would probably try to go one at a time so that Toyota doesn't get angry with all the simultaneous connections.
Alright guys, signing off as I move back up to Gainesville for the semester... any further reqs will have to wait until I get hooked back up and online.
------Nate
Good Afternoon,
Would you please set up a 2006 Tundra Doublecab "Package" for me?
Thank you,
John Hoyt
