Fuel pump adjustment
Pakistan
I have LC 100 with 1HD turbo manual transmission
I loose power in 1st and second gears with a huge cloud of black smoke behind me
Any solution
Do you have trouble codes? Check engine light?
Is the intake clean and free of air leaks?
You can’t adjust the pump on these, and it’s not unheard of the pumps to wear out sadly:(
Also what year is it? Because the facelift models have a tricky intake that can open and close intake ports. That can stick on those and give you similar symptoms
The engine is non efi
The nozzles are new the pump is stock and the turbo is fine
It’s 12 valve 1HD turbo
Ah my bad. I somehow thought it was the FTE.
