Fuel lines and bubbles
Squash
Sudbury, Ont. CA
Because winter is near I decided it best to ensure my fuel supply was in good shape.
Noticed that my Webasto was cycling at times, upon investigation air bubbles were present in the Webasto clear fuel hose.
Now, where to start.
The lazy way was to cut and splice a new joint, but that failed, so I bit the bullet by dropping a 5' section of hose with a 2' clear hose into 5 gallons of diesel. As suspected, while hitting the primer clean un bubbled fuel flowed like magic. Now to crawl around and swap the section of hose from the hard pipe under my feet up to the primer.
Added my Webasto "T" with clear hose and everything is working as planned.
Note: Used 5' of hose because I couldn't bear to cut it...
