Lexus loaner FTW, thank you Lexus of Tulsa!!
Now I’ve had to take care of the following.
Leaking Cam Tower
Radiator and water pump
Fuel level sending unit
Can shaft position sensor
Plastidip it’s doing fine, I just touch them up every couple of months. Love the look!What did you use to black out your wheels? Paint, powder coat, plast dip ect? How is it holding up? What would you use next time?
I am looking to do the same with my stock wheels.
It read 1/4 tank when it cut out.Given you were having it towed, was it the sending unit that went bad, or was it the pump? I would've thought if the sending unit went bad the truck would have run, but the gas gauge would have read empty
Man, I just had the same thing happen! It was sad to see the lc on a flatbed darn it. My mechanic says its the fuel level sending unit, and he has seen this a few times with tundras and sequoias. My wife was taking a whole pile of kids to volleyball practice last night and calls stranded on the side of the road, fuel gauge read just under a quarter of a tank at that point. Cruiser is at 160k. Funny because ours is almost a carbon copy of yours, 2008, ome 2inch lift, 275/70 bfg tako2s, white, love it. have a 96 too!
Ill post with more info on the repair as he digs into it today.
Side note, the tow truck driver said that he has only towed two land cruisers in 5 years, mine being the second, and the first was due to a wheel coming off after tire work was done...
they are indeed very dependable!
To be clear - the truck would have still run had you put fuel in it?
Tire size, lift? Thanks!Plastidip it’s doing fine, I just touch them up every couple of months. Love the look!
Yes, it ran out of gas!To be clear - the truck would have still run had you put fuel in it?
In my signature.Tire size, lift? Thanks!
Lol, thanks...could not see on my phone!In my signature.
