My 88 62 just underwent some cosmetic repair. Got rid of the usual rust, patched what needed it and a new paint job. Since then it has developed a problem with the fuel system.
I can get it started but when i put it in gear or hit the gas any the engine begins to stall and eventually quits. I replaced the fuel filter, same problem. The fuel pressure was checked by hooking up a gauge and jumpering the pins on the check connector on the firewall and turning on the ignition switch, and it was around 30 psi. I don't think it is the fuel pump, at least i hope not, don't really want to take down the tank. Could it be the regulator?
My repair manual says to pinch the fuel return line and if the pressure went up it is the regulator. But the pressure did not seem to change any.
As a side point I was thinking about putting a dual exhaust with glass packs. Do you think that would help the engine breathe a little better and perhaps get a little better fuel economy?
thanks
thanks
