OK here it is, the complete diesel 60 project minus the mechanic. Start with a BJ60 (left hand drive) and transplant in the 13B-T motor, install the lift springs, put on some 33”s and you have a sweet 4 wheeler/expedition rig that gets 22 to 24 MPH! I really didn’t want to have resort to selling it but with another pending move and a lack of the most critical resource - time to work on it, something has to go.
The Truck:
1983 BJ60 (Canadian model)
3B Diesel engine (already pulled and on an engine stand)
H55 Trans (yes the much sought after 5 spd.)/ Split Case TC
PS, PB, No A/C
Stock rims, stock size tires
12V electrical system – yes this is a 12V not a 24V system
Clear AZ Title
History (as it was related to me by a reliable source):
A gentleman bought this truck in Canada and soon after moved to New Hampshire. He then retired to Tucson where the truck has been for 20+ years. It has long since dried out from its northern life and has very little effects of northern winter driving. The truck had been well cared for mechanically before the cylinder head cracked (common for very high mileage 3B’s). It had 493K kilometers (almost 300K mi.) before that happened. The truck would still crank when I bought. It does not appear to have been abused or even wheeled hard, country road driving at worst.
Body is a little rough. It has dents and dings, a few very small rust holes over the rear fender. All the glass is good. The interior is not too bad. Driver’s seat is well worn. The dash pad is in fair condition. It needs a new front carpet and new headliner. Rear carpet and rear seat are fairly decent. I wouldn’t look to restore this truck but it would make a great expedition or trail truck.
The motor and bits:
13B-T Motor with 118K miles on it, take out motor from Japan imported by Japan 4x4. Direct bolt in to the BJ60 as it shares the same footprint as the 3B.
Freshly resurfaced 13BT flywheel
3B flywheel
13BT flexplate (came on the motor)
New 13BT clutch kit from SOR – clutch, pressure plate, throw out bearing, alignment tool
Pictures of the engine bay prior, during, after removal for reference and routings
3B Motor pulled from truck. In tact with essential items still on it, EDIC motor, injection pump, injectors,etc.
12V Starter
24V Starter
12V Alternator
24V Alternator
13BT bell housing
3B bell housing
A/C accessories off of FJ60 – condenser, compressor (12V), some of the cooling lines (needs interior parts – evaporator, ducts, etc.)
4” Lift springs with boomerang shackles – may sell separately or part of the package
Needs:
Motor installation
12VDC VSV - I have the part number, some other common Toyota VSV’s will work too
If you need the glow screen system for cold starting (highly unlikely here in Phoenix) you’d need to wire that
Run a return line to the gas tank for the 13BT injection pump
Connect exhaust - some on the Mud diesel forum recommend going to a 2 ½ in exhaust but its all straight pipe with no muffler needed.
Re-assembly of grill, cross member, hood, etc. – I have every nut and bolt taken off the truck bagged and tagged with labels of where it goes.
Some cosmetic work depending on how nice you want the truck. Likely a right front fender and rear hatch frame.
The price:
I figured that I currently have conservatively $8500 into this project. Sadly, and I’m sure regretfully I’m willing to let it go for $6750 for a fellow club member. It’s all here in one place for one stop shopping. All the big stuff has been shipped so there are not much more in the way of money that needs to be put into this project. The usable 3B parts could be parted out for $500 or more (starters, EDIC motors, rebuild able injection pumps bring big buck from the Canadians) or you could buy a new cylinder head and rebuild it yourself. I’ve probably forgot a few details so feel free to PM me and I’ll shoot you my cell so you can hit me with questions or come by to see for yourself (located in the NW Valley).
Price SOLD!
Truck pics:
The Truck:
PS, PB, No A/C
Clear AZ Title
The motor and bits:
3B flywheel
12V Starter
24V Starter
12V Alternator
24V Alternator
13BT bell housing
3B bell housing
Needs:
Motor installation
The price:
Price SOLD!
Truck pics:
