- Year
- 1996
- Vehicle Model
- 80 Series
Selling my 1996 toyota land cruiser fzj80 100% california car NO rust
25,000 will come with different set of wheels/tires NOT the silver.
1996 Toyota Land Cruiser Maintenance/Upgrade List
Oil Capacity 7.8 quarts
Torque 18 ft/lbs (oil drain plug)
05/08/22 221,030: Purchase, replaced rad cap
05/09/22 221,246: Replaced air filter, hood struts
05/27/22 221,340: Replaced pesky heater hose, valve cover gasket, all spark plugs (oem)/spark plug seals, oem spark plug wires, distributor cap/rotor/o-ring, front main seal, oil pump seal, radiator (koyo), upgraded blue fan clutch, water pump, thermostat, coolant flush, coolant hoses, heater valve, heater hoses, PCV valve/hoses, OME 3” lift kit, ARB bull-bar (non-winch), oem oil cap, oem gas cap, oil change 5w-30 full synthetic, orm oil filter change, all oem drive belts, oem outer weatherstrips, oem front inner weatherstrips
06/10/22 221,600: 4.88 Nitrogears, Front/rear Eaton e-lockers, knuckle/bearing rebuild
06/12/22 221,716: Replaced power steering pump/hoses, installed Slee Off-road Sliders
07/01/22 221,832: Replaced catalytic converters (Magnaflow)
07/11/22 222,040: Front/rear differential oil change Nitro 80w-140 break-in period (changed fill plugs); Replaced sway bar bushings front/rear; Transfer case oil change Valvoline 75w-90 gear oil (changed drain/fill plugs), Installed oem jdm bud deflector, Bowfin roof rack; Replaced positive battery terminal
07/23/22 222,120: Replaced front sway bar links; installed Slee front sway bar drop kit; transmission fluid drain and fill
08/27/22 222,500: Installed Radius Fab snorkel and airbox
10/08/22 223,028: Oil change Castrol 10w-30 full synthetic high mileage; OEM oil filter; replaced oil drain plug (OEM)
12/18/22 224,400: Replaced brake rotors (Bosch front; Power Stop rear); Akebono brake pads; OME J-springs rear
01/22/23 225,201: Oil change Mobil-1 10w-30 full synthetic; OEM oil filter
01/28/23 225,321: Replaced speed sensor sleeve
06/22/23 226,888: Oil change Castrol 10w-30 full synthetic high mileage; OEM oil filter
12/09/23 229,384: Oil change Fram 10w-30 full synthetic high mileage; OEM oil filter
05/28/24 230,347: Oil change Valvoline 10w-30 Advanced Full Synthetic; OEM oil filter
11/16/24 231,475: Oil change Pennzoil 10w-30 full synthetic; OEM oil filter
