New Headlamp (E Code) Installed
Brake
Brake Pad Replaced
Rotors Checked (Replaced Front)
Suspension
Front Wheel Bearing / HUB Greased
Front Axel Hub Gasket /Seal Replaced
All Suspension Parts Regressed.
Shock Absorber Inspection (Check / Replace)
Fluid
Coolant Flush Toyota Fluid
Fresh Coolant Toyota Fluid
Engine Flush Toyota Fluid
Fresh Oil Chevron Delo 400
Power Steering Toyota Fluid
Clutch Fluid Flushed
Brake Fluid Flushed Toyota Fluid
Gear Oil Chevron Delo 400
Differential Oil Chevron Delo
Transmission Fluid Chevron Delo
Mechanical
ConRod Bearing (BEB) Replaced
Thermostat (Replaced)
Water pump
Radiator Cap Replaced
Power Steering Belt
Alternator Belt
AC Belt
New Radiator
Filter:
Air Filter
Fuel Filter
Oil Filter
Miscellaneous:
New Wipers
All Hinges Greased
All Bulbs Checked
Tire Pressure Checked
Complete Detailing Package (Interior, Exterior, Enigne
