Front Vent Window Disassembly
Santa Fe, NM
Website
www.billstengel.com
Hello!
I’m working on replacing the rubber bits for the front windows and can’t get a fix on how to get the lower bracket for the front vent window apart.
Anyone have any insight?
Hello,
One bolt fixes the vent window to the door.
The vent window is attached to the window frame with three bolts.
Juan
Hello,
Juan
Thanks Juan.
It’s the one at the base of the pivot that I can’t get at - whatever is below the spring.
…or is the move to pull the whole assembly from the door, this giving easier access to that pivot?
Hello,
Try pulling the whole assembly.
You may have to remove the window glass run guide if this does not work.
Juan
