Commonly related to the sunroof drain system. Drain tubes exit into the rocker panels, where they then drain through a tiny slit to the ground, which is easily clogged. Tubes get backed up, sunroof tray gets overwhelmed, finds its way on top of the headliner and can come down the A-pillars onto the floor. Can be behind the trim, so not always obvious. That happened to mine on the passenger side, and the visible drips I could see were on the plastic trim on the side of the footwell. Can also be the windshield - pooling in the corners, then takes the same route down to the floor. I would check the rocker panel drain slits and clear them, also remove the footwell trim and see if you find any drips behind it - can peek behind the pillar trim as well. While looking for the leak, you can pull the floor drain plugs under carpet to avoid excess pooling.
In my case, I had a mix of both. Was getting water on passenger floor due to the sunroof drain issue, and on the driver floor due to the windshield. Also had water making it to the rear passenger pillar above the headliner and onto the floor. I resealed my windshield and went ahead and sealed my sunroof as I'm never going to use it, as well as clearing the rocker drain slits, and have been dry ever since.
There are a variety of threads with discussion on the topic and how to address it. Search function on the forum isn't great, so I suggest using Google for better results. Keywords + something like "80 ih8mud" or "site:forum.ih8mud.com"
